U bolts for rear end to spring's.
Bought some U bolts now wonder if they will be long enough with the six leaf spring's. Any thoughts. Don't have time right now to check it out toooooo busy getting body ready to paint. If any one dose a resto. Make sure you remove all the Epoxy coating form the sheet metal. I suggest to sand blast it all and them prime it your self. I have found rust under the coating and it came out on the rear quarters. Looked like the paint was rejected. Started to wrinkle or spider web. So food for thought. :kartman: Now for a cold one!!!!!!
I will get the old tape measure out and get the measurement tomorrow. Up to the front cowl with cleaning and filling. Thanks Bob.
Thanks Bob. I will measure them up. Think they are that long. Appreciate it. Have a merry one. :thumbsup2: Yep they where as you described. 7 inch from the back inside to the end of the bolt thread's. Thanks again. I can go ahead and clear coat them.
Coyote
Columbus, OH
Who’d a thunk it:Thanx!!!
What is that Coyote. I appreciate any help I can get. All the guy's have helped in this resto. Even if they know it or not. Seeing the other runners here keep me going till mine looks I ought to. So thanks guy's.
