I will be installing my 6BBL on to my 69 RR 440 . Will be installing new valley pan and was wondering if I should use a Valley Pan with open or closed heat cross overs ?
Closed unless you drive the car a lot in the winter...which I suspect that you do not. The primary purpose of the exhaust heat crossover is to improve cold weather drivability.
