rollie
- Joined
- May 14, 2013
- Messages
- 52
- Reaction score
- 1
My runner has 4 wheel manual drum brakes. I would like to change the front from drum to discs to make it safer to drive. The car has 15 inch rims. It's been recommended that I stay with manual and install 'common' discs in the front, common meaning parts from the early 70's that are easy to find and replace............. say like the disc brakes off a 74 Cordoba (single piston). A friend of mine has had this done and while they work fine, and the car stops in a straight line .........the car does not stop any shorter than it did before with manual drum brakes............so what's the point ???
There are lots of kits on the market with 3 and 4 piston calipers. Should I expect better stopping with multi piston disc brakes or is the problem that the system is manual rather than power? How much of a big deal is it to change to power if that's the only option?
Any information/opinion appreciated.
