69 Roadrunner-RM23
General Description
Plymouth Road Runner. 100% Numbers matching RM23, 383 4 speed Roadrunner,includes engine, transmission, rear end, intake & exhaust manifold, radiator & waterpump, Matching VIN is present on rad support and trunk lip and fender tag. Refinished with the Y2 Sunfire Yellow it was born with, correct interior, (V1)vinyl roof and (V6W) factory stripe. Basically the only items not original are the battery, ignition, belts and carb. The complete powertrain was rebuilt 3 years ago and runs perfectly with about 200 miles since rebuild. This California car has original floorpans & all body panels all excellent. Trunk pan was replaced at some point. Interior completely redone with correct NOS seatcovers, headliner & carpet.. I verified all numbers on the block, transmission, rear end , intake & exhaust manifolds. 633 LH mirror, L31 fender turn signals, M21 roof drip rail, D21, HD 4 speed,A01 Light package, E63, 383 Magnum and the famous Beep Beep horn of course. A great example of the 69 RR A14 spring special with vinyl top.
Comments
looks outstanding, quick question...is that pie tin from dodge? mine has "roadrunner 383" on it.
Item information
Category
RoadRunners
Added by
zeronetzero
Views
700
Comments
Last update
More in RoadRunners
