3-speed wiper
fugges
Germany
Hello,
the wiper of my Runner does not stop like I know it from cars.
It stop exactly on this positon when I put the button in off position and if the wiper is in this moment in the middle of the front shild it will stop exactly in this position and does not go in the corect positon like it should do. I think the relais (German word, I hope in english it is the same word) is broken.
Is the relais of the wiper just behind the switch?
If I change it it should work corectly or how I have to fix this problem?
This part should be the right on, doesn´t it?
http://www.ebay.com/itm/68-69-70-CHARGE ... f3&vxp=mtr
Or maybe someone here can offer me a working one?
Thanks Armin
A31PKG
Mid-Atlantic
Armin, if the wipers do not park as you describe, then the park switch inside the motor is likely bad. The ebay link you provided is for the dash switch, which (unfortunately) is likely not the problem..... Sounds like it's time for a new wiper motor!
Yep, the park switch inside the motor is broken.
English spelling for relais is relay and there's none in the motor.
Mopar used to offer a repair kit for 3 speed wiper motors. I don't know if they still available anywhere.
I had Jules Daddio rebuild one for me. Not cheap, but it's a thing of beauty.
http://www.julesdaddio.com/wipermotors.html
Sounds like the motor is just not parking properly. The park function is located on the reverse side of the switch plate and is a fairly easy fix if you want to contact me?
kim@passion4mopars.com
Hit me up and I can send some info that might assist you?
Kim
