FOR SALE 4-speed 1966 charger all original 4-speed 383 runs great must sell ! 16,500
ev2wing
Port St. Lucie Florida
:beep: 4-Speed Dodge Charger
All Original MESSAGE FOR CONTACT INFO OR TO MAKE A DEAL
1966 Dodge Charger, 383 4-barrel, 4-speed. Mileage shows 67,200. It is going up slowly as the car is driven. Clear VA title in my name, mileage shows exempt due to age.
All original, almost 50 years old. The motor, transmission and interior are all original. The motor and transmission have been freshened with a list of work done below. The wheels, tires, and air cleaner have been changed. The original air cleaner is included as well . Car will drive home anywhere.
Must sell was $19,500 - - reduced - - $17,500 - - 16,500 ) -- or Best Offer
The all original interior is really in very good shape, including the door panels, headliner, dash and gauges. All lights, signals, wipers, horn, gauges and original radio work. The factory tac in the dash and the original clock mounted on front of the console are not working.
The 383 HP motor is original and recently tuned up. The car drives great. It is strong, smooth and drives and brakes straight.
The 4-speed transmission is original and was rebuilt, with receipts and items listed below.
The car looks good and runs great but has some rust mostly low on the quarter panels, and two spots in the bottom of the trunk center where the spare tire goes were repaired years ago.
The car needs and deserves a repaint, some easy repair , and details , including new carpeting and front seat covers to be much nicer. It has had one repaint in the original color on the outside body only about 25 years ago. Paint is cracking, has blemishes, and is showing its age. Car has been used, and enjoyed, and pretty well cared for, for its age.
All original "383 H.P." 4-speed First year Dodge Charger, runs great!
The car has its original bill of sale (factory sales order).
Original certi card
Original fender tag, decoded, showing options
Original door vin tag
Radiator support numbers match
Original keys and key chains
Original trunk jack assembly complete, nice, with original instruction sticker
Original 1966 owner’s manual with original owners and dealer’s info. typed in back
The following work has been recently done.
Tune up including Points, plugs, cap, rotor, and wires
New battery ground cable
Air and gas filters and oil cap
New clutch and pressure plate
New clutch bearing and new pilot bushing
Flywheel resurfaced
New transmission rear seal and all gaskets and fluid
New heater hoses and clamps
Power steering pump rebuilt and new return fluid hose
New gas tank and filler neck pipe and grommets
Rebuilt carburetor
New valley pan gasket and insulation under intake manifold
New valve cover gaskets
Painted correctly valve covers and manifold message with any questions, Peter, $19,500 OBO must sell REDUCED 16,500.00
Do the dash lights work, do the head lights rotate correctly, and what is the story behind the '67 turn indicators on the top fender trim?
ev2wing
DASH LIGHTS WORK NICELY , AND HEADLIGHTS OPEN AND CLOSE GREAT . THE TURN SIGNAL INDICATORS WORK , AND HAVE BEEN ON THIS CAR SINCE NEW I WAS TOLD. I HAVE SEEN A FEW OTHER 66 CHARGERS WITH THEM . THE CAR RUNS GREAT , AND IS ALL ORIGINAL WITH ONLY 1 REPAINT ON THE OUTSIDE ONLY @ 25 YEARS AGO.WE ARE MOVING 750 miles in a month is ONLY reason for sale. THANKS Peter
