69 RR rebuild NSW Australia
hotcob
Just thought I'd let you know that I got stuck into the strip down this last few days. Pulled both front guards off (fenders to most of you), removed both windscreens - the front was cracked so that was easy, got the rear out in one piece - great. The window trims were pretty hard to get off with a lot of dirt and mastic in there but finally got there with no damage. Removed the vinyl roof and drip rail mouldings and took the dash out. Very little rust found. Bit in the corners of the rear screen but not through the metal, surface rust on the top of the sill plate in front of the door pillars and nothing showing on the roof. Pretty happy about that.
That sounds like a very solid piece so far :thumbsup:
