727 transmission filler tube / speedo gear
roadrunnerh
Pittsburgh, PA
So the filler tube on the 727 I purchased last week had pipe thread tape around the bottom of the filler tube to keep it snug. Well, I removed that along with the pan and filter to inspect what I just bought.
Now the filler tube is kinda loose, it still has the little rubber "O" ring, and the hole in the trans body doesn't seem F'ed. Should there be another rubber grommet? Is this tube incorrect?
Anybody have a 727 dip stick?
Anybody have a red 36 tooth speedo gear?
did you just need the dipstick or the tube as well Harry? I should have one.
