906 head question
jerrysdustydog
Williams, Arizona
I have done a little reading on Mopar engine history, but I am not a guru by any means. On my 68 383HP, It has 906 heads, Has this been upgraded? Or was it possible to get the 906s in 68. Was just asking, for everything I have read pretty much says the 906 heads were only built in 67, right? And if the 906 heads are not original, how much HP was added just by adding these heads? (If everything else remained stock). Any suggestions would be apprecated, as maybe soon I will be getting around to building the 383. Are modern carbs the way to go? and if so, what carb do you guys suggest I go with to somewhat perform @ 7,000 ft elev? I know, maybe a joke. Thanks, J
