Anyone use a wilwood MC on a Bendix booster?
bigmanjbmopar
Wondering if anyone as done this set up and what parts did you use?
Thinking of usig the the wilwood MC POLISHED 260-8556P
http://www.wilwood.com/Images/MasterCylinders/MasterCylinder_Photos-Large/260-8556-P-lg.jpg
On the Bendix power booster, but the bolt pattern is different.
I see you can get a plate, think its used as a delete plate?
http://ep.yimg.com/ay/yhst-13354943...-or-power-brake-booster-upgrade-bracket-3.jpg
Or is there a better way?
It is usually easier to use all one manufacturer for these type of situations. All designed to work together. When mix and match can run into troubles with piston size and stroke.
bigmanjbmopar
Its not a stock application now so no worries. Have you ever tried it before or know of an adapter plate that works?
Never tried it. Currently use the brake mc that came with my brake kit. Mine is just a manual brake, don't have a booster.
