Auto shifter mounting
tvtn
Emmett Idaho ( south west Idaho )
I have a 69 RR that was a 4 speed, and will be an auto. My question is how could I use the existing hole in the floor to mount a floor shifter? Please share your ideas on how to use what is there? or what you did to mount your shifter.
Tom
Hello Tom. Mine had an auto in it. They had put the shifter on the hump but was a bad job have heard that some shifter's have a cable to it. Look into Classic industries do you have a console or not. Also summit racing parts. Hope this helps. Russ. :usflag:
dmartin
The floor shifter should have one maybe two rods to connect it to the side of the tranny, less linkage than a column shifter
Floor shifter is located to the right of the 4 gear shifter. Which is why hump not present in auto car. Never had an auto so not sure about connections
