axle leaking gear oil
since my abuse at the airport ive been changing things for the better...like lowering fuel filter and fuel pump below the fuel cell......well while figuring out what i am going to do i look over and see gear oil leaking out the drum on the slick....upgraded my axles to moser...stock splines with new bearings around 5 years ago..i dont think i replaced the inner seals..dana 60..what kind of job is this??...i hope the bearing is still good....i guess i will get into it tomorrow and find out
I called moser and asked if he though the bearing might be bad...was new 4 years ago....5000 miles....and said no...is a sealed unit ...he said most likely was the housing seal.....so thats what i am replacing
Hoosier Bird said:
We want pics of this process................
too late...its all together,,,,,no big deal....slide hammer gets the seal out....then i use my seal installer and beat it in place...done deal
Hoosier Bird
Hope, Indiana
:toetap: :toetap: :toetap: :toetap:
I figured that it would be a non-event...
