back seats
fugges
Germany
Hello,
I chanced already the seat belts in the front, that was easy!
Now I will change the belts in the back, too. How I have to rebuilt the back seats that i can change the belts?
I'm taking a shot here and guessing your asking what you have to do to take the back seat out? You'll need to remove the rear window handles and the rear armrests. Then you need to push in on the bottom of the rear seat cushion(near the floor) one side at a time and push in. You should feel the bottom cushion pop up. The you can pull the bottom out(look for your build sheet while you have the seat out). You shouldn't need to pull the top cushion out to get to the belts, but you may want to to see if your build sheet is there.
fugges
Germany
Ok, I will try on the weekend!
Somebody got a photo from the backside of the back seat bottom?
Thanks
