Blown Head Gasket
glhcarl
I blew a head gasket last week, while taking off the head I found this. Luckly the only damage was the rocker, push rod and head gasket. I even found the small rounded piece of the rocker that got pushed out. After repair have put about 30 minutes on engine and it runs like a top again.
Yep, seen a bunch of those over the years.
Sometimes the lifter will pop out and you'll lose oil pressure.
you got lucky...good for you.....did you shave the head??or did you have it check.....it not it could happen again
Looks like the lock nut is missing on your adjustable rocker arm... :lmao:
You must have been ecstatic to find that little round chunk of metal; no one wants that kind of crap floating around in there...
Ray
