Brake line routing
I am not sure how it goes on the passenger side. The line look's like it would go through the splash shield hole. It is not bent to go under the frame rail like the driver's side. If any one has a picture or information it would be a big help. Thanks Russ. :thumbsup2:
Big Mo
Pa. USA
Russ, are you asking about the fuel line? On my 68 the fuel line runs up the passenger side. I do not have a pic of it as I am still learning the pic posting. How ever I just ran mine two weeks ago. The brake line on mine runs under the frame in front of the rear tire. If you look where the holes are for the line clips that helped me. Then it runs up and bends over to go through cross member then up to back of distribution block. As for the fuel line it also goes under the frame in front of right rear tire. It runs along the frame to the cross member where it bends it to go through member and up to engine compartment. That is how my 68 lines run. Hope this helps you, Big Mo.
Yes thanks Big Mo. I got the fuel line run from the back to the front also the brake line. Was just puzzled on the passenger side. Found a pic that 69hemibeep posted. Odd that they would run the driver's side under the frame rail and the passenger side threw the splash shield. Appreciate the help. Russ.
