Charging indication
Pete
Phoenix Arizona
Howdy. I have a 74 roadrunner-charging needle on the dash shows a charge all the time. It used to not do this. When I put a meter on it, it shows 14.2 volts across the battery when running. It shows 14.9 volts between alternator and battery ground. Is that normal or is it an issue? I tried replacing the ballast resistor, no change.
Ideas?
Ballast has nothing to do with it. How many volts does the battery show with the engine and lights off.
Pete
Phoenix Arizona
I had a 73 Roadrunner years back. This 74 like the 73 seemed like the ammeter would go to the charge side when started, but after it ran for a while the needle would move to the middle. I just put a new 130 Amp alternator on it, so it looks like the alternator keeps up now. But on any of your vehicles, does the needle still lean to the charge side? Mine does, but the alternator is putting out 14.2 amps now.
