Clutch and brake pedal
On the upper linkage looking for the plastic bushing's and the felt washer's where the bushing slides through them to hold them in place. The needle bearing's look good. Also their is a plastic washer where the brake spring hooks to a pin. If any one knows where to get these parts. let me know. I looked into classic but no help. I am cleaning all the rust off all the part's and giving it a fresh coat of paint. Yes something besides the body. While waiting for the leaf springs paint to dry am cleaning up other part's. Thanks Russ. :thumbsup2:
Thanks TOMRR. I will try them and several other's to day. Think all I need is the plastic bushing's. They are some what worn and one the out side lip is broken. Also the felt washers. Their is only two of each but it is apart and figured to replace what look's bad. Russ.
Well as you know in a rush to get them I found them at Herbs part's. Appreciate the help. Year one wanted 11 dollars a piece. Well their on their way. Thank you again. Don't know why I did not find them in my mopar book for classic. Now to get the felt seals for the clutch thinking to put O rings in their should do the same thing. Russ. :thumbsup::thumbsup:
R/T has a lot of OEM stuff or close to it
Yea I looked their also. These bushings where broken on the ends or just wore off. Like I said got them from herbs parts. Sand blasting all the parts and painting them While also working on my other leaf spring. Going to paint them today. Then clear coat each leaf tomorrow. Seams like every thing take for ever to get done. Russ.
Yes wearing Goggles-respirator-and sand blasting hood. Can't stay in that too long. It is a melt down for me. :thumbsup2:
