Coolant capacity?
Nested69
Sacramento
Hello all, I have a 1969 Plymouth RR 383 automatic, with a 4 bl. I just flushed the radiator, and the engine. I was only able to get around 2.5 gallons of coolant back in it. To be honest, not much came out when I drained the radiator. This is after burping the system, with the heater on and off. I have read the system is supposed to take like 4.2 or so gallons. It won’t take anymore. The car is number matching and absolutely stock. It is not a AC car. Can anybody help me with this?
Sounds about right. The heater core is full and you can only drain the block to the bottom of the water pump so the block is holding quite a bit yet.
