Cranks but only fires in run
Terry Hauck
Choadicus
Mojave Desert
69 Roadrunner with orange box ignition. Turn the key, and it cranks but won't fire till I let the key spring back to the run position. The ballast checks good at 1.5 ohms. After it starts, it runs great.
There are two run positions on the switch, the one while using the starter isn't working. Chase that circuit.
