Door window Plastic edge seals
joewhite440
Industry, Pa
Anyone know where to get the door glass front edge plastic seals and the pin that holds them on?
Thank you
Joe
dmartin
year one they are about $72.00 a piece, when you put the new one back in put it together from bottom not the top cause it will tear them up, belive me from experience I had to buy two of them
Still available from your local Chrysler dealer with the part number listed above. If you know someone that is in the cost + 10% program, they are about 48 bucks each. 2 needed per car. I recommend filing the "T's" a bit to let the window move in the track a little bit easier. They are just a bit to wide, and will cause the "tear" that dmartin is talking about.
