E brake install
Have the nuts for where it goes through the fire wall. The question is. Is their a spacer that goes behind the e brake where it bolts to the hinge panel. Seems like it is being pulled pretty far over if it dose not get a spacer. This car came with out it when buying. Just one of those things where you did not have a chance to take it out. Russ.
Really. Ok thanks for the heads up on that. It just seemed to be pulling quite a bit. Hell I don't know. But thanks again. Russ. Frustrated.
