Electric fans
bstan70rr
The last time I asked about these, I think the responders were thinking I was going to replace my original fan with with one that is electric.
I was actually thinking about adding one to help out when it the temps hit 100, the AC needs to be running, and the cruise traffic starts slowing the airflow down.
I have never really ran too hot, but I just installed the AC unit, and I am sure the extra pull is going to add some degrees to the system.
Any suggestions???
i used spal fans.....expensive but really worked great......make sure you install relays so you have a true 14 volts running them
