Electrical Stuff
zupanj
Yardley, PA
I took the Runner to an auto electric shop to check the charging system since the ammeter jumps around so much. It looks like the alternator is bad and they are going to rebuild it. While testing the car the guy noticed that the only ground is from the battery to the block, there is no direct ground to the chassis. He says I really want to have one. I did wonder about that but there was no ground to chassis when the 383 was in the car and I didn't add one when I put the hemi in. Do other Roadrunners ground to chassis or is this some Mopar quirk?
i dont know what is correct but i have a ground from the block to the firewall and from the block by the motor mount to the k-frame......and she is grounded
Jack. Can you see the wire from the fire wall to the intake just to the right of the ballast. I believe this is the same location as wedge engines just a different length wire. I'll look for the place I got mine from :thumbsup: If you have the battery in the trunk by all means add one from the block to the chassis. I just realized that pic is prior to getting the dashpot. but that would have cluttered it up anyways :lol:
Jack I got my wire from Mopars by Crane and they went under :toetap:
I've always seen a factory ground from the rear of the passenger side head to the firewall. and the headlight wires have a ground to te core suport.
zupanj
Yardley, PA
Thanks guys. Bob your pic was especially helpful. I think I remember that ground on my '67 GTX. I checked my car and there is in fact a place for a bolt to attach. I will pick up a ground wire from Year One or Mancinis.
Jack
Jack
just buy some ends and make it yourself.....no big deal
SomeCarGuy
Sometown in KY
I always run a ground to the ECu and the VR for good measure. I have a heavy wire from the head to the frame.
