Oct 17, 2016 #1 RR383 Well-Known Member Joined Jan 30, 2016 Messages 358 Reaction score 1 Location Tennessee Fellows I'm having a bit of trouble de-coding the casting numbers on my block. Casting Number: 2468130 3 4-7-71 What do I have under the hood?:huh:
Oct 17, 2016 #2 ArmyInspector Well-Known Member Joined Jul 18, 2012 Messages 163 Reaction score 6 your block casting translates to 383, 1959-71
Oct 17, 2016 #3 ArmyInspector Well-Known Member Joined Jul 18, 2012 Messages 163 Reaction score 6 if you want to know more about your engine, you would have to look at the vin in conjunction with the other stampings on the block.
Oct 17, 2016 #4 69hemibeep Sponge Bob Square Wheels Joined Sep 10, 2008 Messages 22,251 Reaction score 2,495 Location AZ Desert, Casting date is pretty easy 4-7-71
Oct 17, 2016 #5 quikbird Well-Known Member Joined Mar 1, 2014 Messages 3,304 Reaction score 1,111 Location Sarasota, florida the little pad on the front of the engine should have some stampings that will give you a little more info
Oct 17, 2016 #6 RR383 Well-Known Member Joined Jan 30, 2016 Messages 358 Reaction score 1 Location Tennessee quikbird said: the little pad on the front of the engine should have some stampings that will give you a little more info Click to expand... Yes...I found that right front passenger side at pan rail. VIN...correct?
