ALX69RR440
Hello all,
Ok I finally started to work on the car and I have a question. The car pings at around 4500 RMP. The initial timing is 13 and 32 total at 2500 RPM. I’m running 91 gas. I tried backing off the timing and it still pings.
I replaced the cap/rotor, wires and plugs (champion something or other) I have an MSD so I set the gap at 50 (is this ok? Old plugs were set at 40. I didn’t notice a change).
Ran the car and still pinging at 4500 RPM.
By mistake I filled the tank with 87. On the way home pinging started at 2800 RPM.
I pumped all of the gas out of the tank and put in 5gal of 110 leaded and 17gal of 91. Pinging stopped! And is running great! Question is, previous owner says car is 9.5:1 compression. 91 should be good right?
Engine info:
68 440 HP Performer RPM intake Holley 750 mechanical secondary
Cam unknown (is there a way to find-out approximate cam specs without tearing down the engine?) Only info I found was a receipt that said "cam 270-280"
Mopar performance distributor
MSD 6AL
Thank you!!
Engine info:
MSD 6AL
Thank you!!
