Hoosier Bird
Ok guys, I've been working feverishly on the 57 driveline getting it detailed. I've stripped all the front end components, sand blasted them, rebuilt them, epoxy primed them, and then painted them with acrylic enamel with hardener. I stripped the rear end, bought new springs and basically did all the same things to this. Took everything down to bare metal, replaced all seals etc.......Now here is my question. I've been watching a couple of restore jobs being done on YouTube. It seems they strip most everything off of the car, replace the metal that needs replaced and then epoxy prime. The weird thing is that they epoxy prime over some areas with some surface rust. Not flakey surface rust but just a slight amount of surface rust. Is this kosher? Will the epoxy primer not let the rust get any worse, ever? Just curious.
