Front Shock Absorber Removal
69 LooneyBird
Pa.
Is there a way to remove the lower front shock absorber bolt without removing the sway bar on a 1969?
as my friend coyote would say," Alabama hot wrench can fix anything"
then run the new one in from the back side
Coyote
Columbus, OH
Alabama hot wrench fixes anything! If it goes too far it needed replacing or welded up for reinforcement anyway!
With a torch you don’t need no bfhammer.:soapbox::steering::beep:
