Full disk brake conversion question
Kinghawk
I have decided to upgrade my brakes on my 1969 Roadrunner.
I have gotten the rotors and calipers and related hardware so far. What parts would need to be upgraded as well? I know a dual diaphragm booster is in order; anything that I'm looking for in particular?
Master cylinder? Proportioning valve?
Thank you all in advance!!
Roadtrip
Alberta
Welcome, tell us a little more about the car and current set up. Are you converting to oem style mopar single piston caliper disc? Or pin style earlier b body disc, or will wood, or? Power or manual?
Rumrunner
Manteca CA
I got what they told me was a complete kit. It wasn't even close. The first thing on the front page of instructions was "Green Bearings (trade name) needed installed on the rear axle" along with spacers. (replace the tapered bearings with sealed ones) I don't know if all rear disk need these.
