Gas leakage at filler end
CWR
Usually when I fill up ( gauge shows full by the way) I usually have some gas leaking from the filler hole around the cap. Also when the rear end is lower than the front, it leaks a bit until the tank is less full. The obvious answer is not to fill the tank............anything else come to mind? Im off to Vancouver for a few days............oldest daughter is 39!!!!!
try a different gas cap..mine did that...are you sure it isn't the rubber seal for the filler neck?
CWR
i have never looked at it too closely but will have a look ,thanks
CWR
I took a good look at rubber gasket on inside of cap..............rubber is split........new cap coming
