Has any one put the lower contorl arm pin in
Just wanted to know if you guy's have put the grease able one in. Where is the grease fitting located. Can you access it. Thinking it must be at the end of the shaft where the nut goes on. Thanks for info if any one has put them in and are you happy with it. Russ.
Yes thanks 69hemibeep. You know they are always coming up with new ideas. So the pin is fixed in the K member and it turns on the poly bushing. Or should I say moves. Yes just want to do it once. :thumbsup2:
