Lower Dash pad
Well found out the one I bought all the stuff is coming off the back. Has any one restored these their selves. I am thinking with what has pealed off back their to fill it with flex seal and see how that work's out. Any ideas would be grate. Russ.
Hell ACME A12 those are welded on. It is that after market trim that suck's. Look's like someone used that spray foam in one place. Dug it out and cleaned the rusted metal under their also. Even had a small crack in one of the corners but that 3m glue work's pretty good. Thanks for the jab and going to fix it up and post pic's when done. :mob:
It aint No boat RAINMAN. All though when sealing it up with the bed liner and seam sealer my buddy said this car should float. May be I will put a boat prop on the back BEEP BEEP. :lol:
