Manual steering to power conversion??
cj69RR
Fleming Island, Fl.
Question on converting from manual steering to power on my 383, 69 runner. I was at the old junk yard this past weekend and saw a 70/71 cornet classic with a power steering box in it, pump and lines missing. Can I use this box and what else do I need to get? I think the intermidate shaft and pitman arm? Thanks for the help
cj69RR
Fleming Island, Fl.
So I need the column? Are the gears the same on the manual column? What parts do I need to pull to get this to work? Or piece this thing together? Thanks for all the help.
preddy
Southern Maryland
If you can't get the shaft, they make a little extender. I did the same thing you're trying to do and didn't have the longer shaft. I think I got my shaft extender from Mancini (that just sounds wrong...) for about $115.
I found a picture of one on another forum.
http://www.forabodiesonly.com/mopar/sho ... hp?t=92943
You're going the wrong way... :lol:
moparstuart
I have not done it but i've heard you can just tap the longer shaft back up into the column and make it work of this change over . Just what a couple guys that have done it told me ???
preddy
Southern Maryland
d0h! I am! Ignore what I said... :banana:
