mopar engine builders nebraska
Larry Chilese
could use some suggestions for Mopar Machine Shops in Nebraska. I have a 383 that needs the bottom end rebuilt-crank-bores and the heads decked. Any suggestions would be appreciated.
Looked on the internet and started calling. Getting prices and visited the shop's. Settled for a one man shop up in Orlando fl. The guy did a grate job for me. The crank had problems' and he found me one. Bought a used block from out of state. Mine was not able to be used. I am not fond of sleeves in the block. Check out local car forum's of who other guy's are using to do their motor work. I got mine rebuilt from top to bottom in about two month's. Getting parts was slow. Maybe some one here in you area will chime in. Good luck on the build. Russ.
