Need some input
I keep looking at it and it overwhelms the engine, yes kinda fugly and I'd have to add a ton of bling to offset it . Think I'll stay with the V-belts. I was going to trade it for a couple of guns I have for sale .
This says it all......
abodybill
Senior Citizen Member
MI. Farm
FUGLY is a good description of them.
Plus to much money for not getting much out of them.:cents:
Bob, did I see somewhere else that you've given up on the idea, or just on this particular piece?
Its just over the top, it all hangs off the water pump housing and looks kinda goofy. I thought I could incorporate my A/C compressor and go to a single belt but then I would have to go with electric fans and I don't want to do that.
Budnicks
Sonora Ca.
69HemiBeep I have some on my 68 RR BB wedge, pieced together one on the power steering {it's a Unisteer rack & pinion}, my alternator & lower crankshaft pulley, are March Ind. serpentine I got them from {March Industries, from Magnum Force Racing} & an idler for my power steering from Magnum Force Racing all 6 rib Serpentine, March dual crank pulley was like $130ish, the alternator was like $50ish, the idler was like $40ish, the bolt-on power-steering pump from Unisteer had a serpentine pulley already, they are like $40ish too IIRC, belts were relatively cheap like $20ish each X 2, I got them from Summit Racing, no water-pump serpentine pulley, I have an electric water pump & fans which you don't have to do, but that's why I used a idler pulley, to clear the bely under the water pump.. I have about $270ish in my set-up, I had to space out the alternator some & made a custom 7075 aluminum bracket to mount the idler pulley & space the power-steering pump properly, I got some various sized 3/8" hole chrome spacers from Orchard Supply Hardware & a couple of washers for shims here & there, some new stainless bolts for hardware for the water pump & alt., power steering mt.'s another $40ish so about $310ish + a little fab time & hardware, in my serpentine belt set-up...
I think before I do anything I'm going to test fit the 440 in the car. Thanks for the info I'll make a note of it.
