Neutral Safety Switch!!!
Lone Jack , MO
I have a 1969 Roadrunner with manual transmission which I understand does not include a NSS only a reverse light indicator. Has anyone added a neutral safety switch and wired if so where did you add the switch and how did you wire?
I suppose you could wire something in between the ignition switch start pin to a switch on the clutch pedal like newer cars.
