New Carburetor 600cfm Summit Racing
Trev3434
San Francisco Bay Area
Hi All,
I need help tuning this carborator I just put on. I'm pretty new to tuning a car like this so all help matters
383 4 speed RR just put on Summit racing series 600 cfm and idle is really high. Adjustment screw does not change much. Sooo???? Any experts out there that can walk me through this?
650-759-9258
make sure you accelerator cable is adjusted properly....take the cable off the carb, and note if the carb linkage moves any.
"Adjustment screw does not change much."..........sounds like he found that yellow boy....:poke:
Yea had to play with my throttle cable Moved it forward a bit. If you have to pull the carb accelerator arm forward to hook it up then their is the problem. Is this a Holley carb. Or Edelbrock.
Did you plug the vacuum hose from the distributor into the upper or lower port if you have one
Trev3434
Sure enough it was the accelerator Cable. Need adjustment. So I took that 600 off and switched to a Holley 750 Mechanical advance. That 600 was to small.
After 40 years with the same warden I just say yes mam. :kartman: What that honey I have selective hearing. No I was not talking about ya. I was talking to the cat!!!!!!
