Power disc brake conversion with air grabber question
Bmygrant
I'm looking at converting my manual drum car to front power disc brakes using this kit...
https://www.getdiscbrakes.com/mdc62dc
I called several different tech lines and no one seems to know if the master cylinder with this booster and bracket will interfere with the air grabber duct. I know the hemi cars had a booted recess cut into them, but I have no point of reference to compare it.
You have no problem. The power brake hemi cars used a bracket that moved the booster and master away from the hemi head so your good. All the hemi cars manual or power brakes got the boot that Ive seen for some reason maybe so they wouldn't miss it. Plus the booster you are looking at is smaller
