Removeing 727 transmission and Replacing with the original a833
Dose any one know if the four speed mount bracket is used with the automatic and will the mount be the same. Look's like the four speed transmission I bought is in pretty good shape the input shaft is in good shape splines look ok. Where the throw out bearing ride's also look's ok. Input shaft has a little play up and down motion. I assume that it need's new bearing's. Going to open it up shortly and go through it. Have a little slop not much when turn in put shaft back and forth hope it isn't a worn gear or gear's. Well thanks bird owner's it is grate to get feed back.
The pilot bushing in the crank shaft will eliminate the input movement. The cross member and mount are different. I don't remember what engine you have or its year
