running warm
its driving me nuts....90 degrees high humitity...car runs up to 210 degrees.....75 degrees 200 degrees....not happy with this....180 would be nice.....one of my spal fans crapped out and the sent me another...not bad since they were 3 years old....still not happy with temp...picked up another meziere 105hd...42gpm electric water pump...changed out the relay[ may have to move this closer to the altenator and wire her up...tested last nite and after the relay i only got 13 volt...should be 14 volts...still not happy...have a high flow thermostat...160 degrees with a hole drill in it ...hoses arent sucking closed.....i guess i should get a dual fan shroud made up..that should help or jet up 2 or 3 sizes in the dominators to fattin her up....maybe leaning out with that blower scoop ....or shit can all this stuff and go back to the stock water pump and fan.....what temps you guys running at 90 degrees??
i was looking on google at these prc radiators and came across a chevy tri five website.and this looks like my problem....
There is one way the thermostat can cause overheating. That's if it doesn't open fully.
I had this happen to me once. The engine would warm up normally and the temperature would level off near the thermostat setting. But if you drove over 65-70 mph the temperature would climb rapidly. It would fall again if the speed was slowed.
A quick check of the bad thermostat and a new in a pot of boiling water showed exactly what the problem was.
this is exactly what my car is doing...this would be nice if its this simple
My car actually ran too cool with a 160 low flow stat.
I put in a 190 high flow and it runs better. Holds 185-190 now. Was holding 170-180 depending on outside temp before.
The AVS hated the cold temps.
I do have a stock bore 383 and a 26 inch radiator. I also have an Edelbrock pump. This is the second car I have ran one on and it is the 2nd car that has ran cool :drive:
I don't fool with drilling the stat either.
I run a 180 in mine with a 26 inch radiator
Runs about 170 moving. at lights right at 180-185
drove her for about 5 hours last Sunday 95 degrees outside
No issues.
But than again just a .040 over 383 with a 355 gear 4 speed
the other problem is the 430 gears....3000rpms at 60mph....i wanted pro-street.....now i want to drive it....355s sounds great
Sounds like that water pump moves some serious water through the radiator...if it moves too fast you cannot cool it sufficiently...sometimes a point that is overlooked...
ACME
ACME
this is a chart of comparison of mechanical pumps......talk about moving some serious water....check this out....Flow in GPM (Gallons Per Minute)
RPM Competitors Pump Stewart Stage 1
1000 .........17 .............................18
1500 .........25............................. 32
2000......... 34............................. 42
2500 .........42 .............................55
3000......... 51 .............................65
3500 .........59............................. 77
4000 .........68............................. 90
4500 .........76 .............................101
5000 .........85 .............................112
5500 .........93 .............................122
6000 .........102............................ 132
6500 ..........110........................... 138
7000.......... 119 ...........................148
7500.......... 127 ...........................157
8000 ..........139 ...........................158
Stewart Stage 4 DRV-
How far is it bored?
