Rust on inside skelton.
When removing rear pop out window and trim found rust in the inner frame work seems to be coming out of roof header over door. Have a bad spot back where the roof and rear finder come together. I would say the frame work where the sail panel goes. Thought would try small wire brush on a rod and try to clean up through the channel over the door Header and use some of the rust convert that is sold by Eastwood with a wand extension that they sell then use the rust encapsulator. Or should I go with a zinc type of spray first after the rust converter. Well just thought you guy's might have done this before or had it done.:confused:
