Stamped steel rockers
Terry Hauck
Choadicus
Mojave Desert
On the original stamped steel rocker bars is there a right and a left or are they universal??
Someone told me the oiler holes need to point to the valves. I cannot figure there would be a left and right but I'm no expert either. Maybe I can learn something here. Thanks.
Can you please explain the difference. I have a ticking lifter on the passenger side and he told me that may be the problem. He has worked on Mopars way more than me but I cannot in my mind think of how it could matter. Simple job to move them but you can probably see I am trying to avoid it.
OK this is what I found. If you took all the rockers off the bar and reversed them the oil would squirt slightly away from the valves instead of toward them. I think it would still work but not the correct way to install them. I also pulled each lifter and found #6 intake wasn't holding solid like the others. Changed it and I am good to go. A little extra work but worth it.
