Superbird Vinh,number
V.R.D
florida
on the drain rail left side where the trunk rubber seal is use a mirror to see revers side then remove seal from trunk rail to see the other is on the radiator core support under the coolant yellow sticker
post the vin and it will tell a fair amount of info
dose it have a fender tag ? if so post a picture of it and the smart people will tell you more and where it was made . but you know all s/b came from one shop / plant? then sent to dealer so post the info for more info
V.R.D
florida
have you heard of for b-body's only ? there is a lot more activity on there and look for Jerry Hall he and Richard the brain know there shit.
VIN shows to be a Road runner 440 Hi Performance 1970 Lynch Rd plant. Like V.R.D. said the stamping should be found under the trunk gasket drivers side.
Also, Rad support should have the vin number. On finding out which dealer ship that is out of the question. I know where mine was sold in what state. But all the dealerships are mostly gone. If so, most paperwork has been trashed. Do you have the build sheet for the car?
