Sway bar install?
woodwiz
Tucson,Az.
Thinking about installing a factory sway bar on the 70 Roadrunner. Should I install it with the car off the ground or can it be done without relief of the front suspension?
Thanks!
Did mine sitting on the ground. But had not loaded the torsion bar's yet. So don't know if that makes a difference or not. Hope it comes with the bracket's on it and the new bushing in them. It was a job to press those into the bracket's. Maybe some of the other guy's will have a better answer. Russ.
Can be installed with car on jacks. Is independent of torsion bars etc. ties into lower control arms but is already at set position by end links with essentially no adjustment possible
