swing gate oil pan
i have a milodon swing gate oil pan with dual lines and the steering link running thru it...9 qt...it has teflone washers and nuts on each side[in and outside] which has been leaking since day one when i installed the motor....what do you guys think on the fix.....rtv silicone...o rings??
I had to o-ring the pickup line on my AMC. In fact my whole life Ive had trouble with pickup lines :lmao:
Tell me the steering arm is not in the oil pan itself! I have seen them around and through but not in!
the oil pan is boxed out so the steering link can run through it and the swing gate pickup swings forward when you hit the brakes and to the rear when you step on the gas
I had one of those in another car years ago... I could never get it to stop leaking.
Hoosier Bird
Hope, Indiana
I have no experience with this but if you give me the right info I'm sure I could figure it out. I only need to know one thing...........what color is your oil pan....... :lmao: :lmao: :lmao:
looks like brass-copper color...its steel with this coating
Hoosier Bird
Hope, Indiana
I'm still not sure, I thought maybe it was painted GREEN.
"Mr Hooiser, there's a UPS truck here. He has your General Lee kit"
Hoosier Bird
Hope, Indiana
You can surely do better than that..............at least you guys keep my mind off of these boneheads I'm trying to do business with....... :lol:
I thought that was pretty good actually... :D
Back to the original post... If I remember right, the fittings that go through the side of the pan have rubber gaskets on both sides. With mine, the RTV never really worked right probably because of the oil. I think the big problem I had was we were over tightening it trying to get it to quit leaking.. and that made it worse.
this set-up came with teflon washers ...no o-rings.....i am going to try black RTV silicone on the out side washer against the pan and see what happens....if that dont work i will have to drop the pan and do the o-ring trick on both sides
gee...you act like we stray all the time.... :jester:
you guys putting anything on the bolt threads?
