Think we found the problem with the engine
nicanor
Sorry for the seperate post.
When we pulled the main bearings we found out the oil supply hole for the bearing was on the bottom and on the top where the port is for the oil supply had no oil supply hole so the bearings weren't getting any oil.
Does this make sense concerning the problems and noise I was having from the oil pan area?
Thanks,
Barry
Thanks,
Barry
They did that to all of them ?
Not to mention out of round journals and main bearing tunnel. This is a major problem and a major red flag. You should take it out and correct all the mistakes the guy made before you make hamburger out of that motor.
X2
And take it somewhere else. Anyone that can make this kind of rudimentary mistake has NO BUSINESS building engines.
jays69bird
Oswego
ACME A12 said:
X2
Great advice,I wonder how many other motors this guy has screwed up by this sort of mistake.
Thanks,
Barry
I bet you had very high oil pressure. I would take a lot of pictures and talk to an attorney. :cents:
nicanor
Oil pressure stayed at 75, didn't lower even at idle. Now the oil pressure follows the rpms.
Thank for the help,
Barry
