Valve Lash
69RunnerMike
Martinsburg WV
I need to replace the valve seals on my 383 and wanted to know if the valve lash needs to be set after I'm done. The manual doesn't mention setting valve lash, so I assume it's not necessary. Doesn't seem possible with the rocker arm shaft design this engine has.
