Vent window gasket?
a6t9vette
North NJ
Whats the process to replace this gasket? Im assuming the glass needs to be removed, but does the whole vent window frame need to be pulled out as well, or is this something that can be done while still in the door?
It can be done on the door but you might have to loosen it up to tuck it in next to the paint.
X2. I did mine this way. It's not that hard.Take your time.You will have to loosen the frame bolts and slide it up and yes the glass has to come out too but it can be done. :cheers: :beep:
