wire harness in
Big Mo
Pa. USA
Today we put the front light harness in. Went pretty good. Had to repair two wires and then figure out where and how it was run. Then we put bullet turn indicators on. It has been way to long since I took things apart. I also put the splash shields in back of and beside headlights. Then the fender clearance lights. Hooked a battery up so I could check them all at plug. A little ground issue on fender light but all the rest worked fine.
Yes when things work it gives you a little pride in your work. If something electrical dose not work always check the ground. :thumbsup2:
