Need help on dash wire.
abodybill
Senior Citizen Member
MI. Farm
I just put a new dash harness in my car it's a year one/M&H harness.
everthing has been a plug and play just as in the FS manual wiring diagram and the color diagram I bought but,one wire I can't find in either diagram and it's a black wire with a white tracer on it.
it's right next to the red wire for the cigar lighter.
Anybody know where this wire plugs into or what it is for?
I know all black wires are groung but like I said this has a white tracer on it.:brickwall: :brickwall:
Look up Bill! I think it may be the ground for the heater fan switch. I just did a Charger and had the same issue and there was a plug hanging from the heater control area.
I just looked at the wiring diagram and there is a black with white tracer wire labeled Q4A-18BK* that runs from the lamp on buzzer to the fuse block. So that would be 18 gauge wire and it looks like it's power for the buzzer.
I've never seen a lamp on buzzer in a Roadrunner, but I'm not surprised if the wire is there.
Thanks Big.
I know that there are few wires in the harness that I don't need and I looked and looked and couldn't find out where that wire went.
I know my car didn't any buzzer on it.
Thanks to all replys!:thumbsup::thumbsup:
I see a C1-14BK* that goes from the fuse box to the blower motor switch. There is a connector along the way, beyond which it loses the tracer and becomes solid black. Does your car have A/C Bill?
That would be a larger wire (14 gauge) than the one I mentioned. Figuring the size will help.
Craig,
No air only when the windows are down and I push on the GO pedal.:thumbsup:
Naw Steve,
I got two models up from your's the 490 model
All 4 windows down and 90 MPH.:D
Yes, but he made no mention of the size so I just looked for a black wire w/tracer (BK*) and saw that one... 'tsall good...
