replacing heater core
72plymouth
Never replaced a heater core before..... mines leaking alittle but don't want to put any stop leak in it......would rather do it the right way! Any help would be much appricated!!! this is on my 72 plymouth RR
RAINMANYEH
Birmingham, AL
Make sure you order the right replacement. A/C vs non-A/C. Remove the lower section of the dash. The heater box should be visible. Remove it and get to the heater core. You could temporarily bypass the heater core in the engine compartment to help minimize any interior leaks.
Take the seat out. It will make it much easier for you and your shoulders.
suck up.......
is it an ac car? if so, check the rubber drain on the firewall in the engine bay. had one plugged up once, and it cause water to leak inside the car
suck up.......
There is no sucking up going on here... Hell, he no longer even owns this site. You're just being pissy because I've never used "wise" and "basketcase" in the same sentence... :basketcase:
you been talking to my wife again.......and shouldn't you be out in your little climate controlled playroom getting that blue rat rod put together so you can sell it to Ass Monkey....
72plymouth
ok this car did have A/C but its no longer their! Will that still make it hard? Take out the seat??? OK more room! Gotcha!!
RAINMANYEH
Birmingham, AL
It makes a difference in the heater core you order as they are different. You would want the one for an A/C car... Especially, if you plan to possibly add A/C back at some point.
With A/C
http://www.classicindustries.com/product/mopar/b-body-road-runner/parts/3441180.html
Without A/C
http://www.classicindustries.com/product/mopar/b-body-road-runner/parts/3579171.html
Mac would be the one to answer this question but I believe the air boxes are different for a/c cars. I don't believe the non a/c core will fit in the a/c box. Send a pm to Mac. He will know.
I have her on speed dial so I can let her know when you're misbehaving...
WTF climate control are your talking about...? You know all I have is a bunch of fans...:toetap:
It's not blue. It's turquoise. And it ain't a rat rod either. :stuckup:
Just finished putting the nose back on it last night. Gonna try to get some miles on it this weekend and get the rings seated. Taking it up to Moultrie, GA for the swap meet in two weeks. Hopefully someone will throw some dead presidents at me and then I can start taking the RR apart for her turn in paint jail. Wish me luck. :cheers:
she just figure's I'm misbehaving all the time....
and you can't play the fence on the color...blue is blue there Blue Boy..looks like Mike Brady Blue to me
bet you're not down to 5 degree's....although we ain't been dodging twisters...buncha snow headed this way after I'm at work tonight...weather goof says anywhere from 1-3 to 6-8"
wish you luck at the meet :thumbsup:
RAINMANYEH
Birmingham, AL
The heater boxes, the controls, and heaters cores are different for the A/C vs non-A/C cars. Look at the connections on the 2 heater cores I linked above. If you've got a car that previously had A/C, get the A/C heater core as it should go back in just as the original did.
